VonTrollicus
- Aug 16, 2020
- 5
Fixing up our new old boat (1996 sea nymph SC 175) and replacing the trolling motor and all wiring issues.
Current setup is (3) 12v batteries - starting + (2) new deep cycles all hooked up to an on board charger.
The deep cycle batteries have their positive terminals hooked up to a blue sea 4 position switch 9001E https://www.amazon.com/dp/B000K2MCR2/ref=cm_sw_r_cp_api_i_4ZAoFb672DDY4 and the negative terminals to a common bus.
Basic 24v wiring for the batteries in series would have me connect the positive from battery A to negative from battery B:
https://www.minnkotamotors.com/sites/minnkotamotors_site/files/wiring-batteries-in-series.pdf
It seems to me this would cause a loop in the system if using the 1+2 option so I'm wondering if there's any way to make use of the switch capability or if I need to swap it for a 3 way switch and if utilizing a common negative bus will cause any issues also.
Maybe just over thibking but don't want to get ahead of myself and have to rewire or replace a bunch of fuses / hurt any devices.
Thanks!
Thanks!
