Re: 24vdc trolling motor wiring question
"This topic has been covered over and over and over but I will cover it just one more time. (There are instructions on how to use the "search" function)."
Thanks for the assumed insult, but I know forums and have used them for many years. I figured my situation's wiring (as you stated "overly complicated") is also "unique" so I figure my questions would also be unique. And I already was guessing that the way you show the batteries wired is the way it should be, with the batteries in series and two wires to the controller. That is why it is puzzling to me. I bought the boat used so I don't know if this was the dealer, Godfrey's, wiring, or the previous owner's wiring. That was going to be my next step, to call the dealer.
What bothers me is that it is purposeful that whoever wired it ran 4 wires from the trolling batteries to the 4 pin socket at the front of the boat. You would think that if it was done your way, they would have run just 2 wires. And this begged the question, "How could this ever have worked correctly if it was wired wrong from day one?" And why was a bank of charging power tied to the starter motor? Was this to charge that battery during the boats down time, all winter?
According to the manual for the charger, you can hook up the banks in multiple ways, including the starter battery. I also looked at this link, and it shows converting a 12/24 vdc system to a straight 24 volt system.
http://www.kencook.net/12to24.html Notice the socket and jumper in Drawing 1.
Anyway, I plan to bring the boat home tomorrow and ohm out all the wiring to see if I've guessed the logic behind this wiring as shown in my sketch, or is there something else that I'm missing. I probably will wind up rewiring it to the batteries in series and two wire method. The charger self regulates to the sensed voltage, so I should be able to charge the two trolling batteries off of one charging bank with them in series (charger across the two batteries). I can then leave the other charger bank on the starter battery. Per the manual, it doesn't hurt to leave this charger on a battery as it is "smart" and will shut down if the battery is fully charged.
