25 EFI fuel pump not work
Sylva-Ranger
Mercury 4 strokes 25 EFI 2006 S/N 0R146130 manual start
Costumer install New Quantum hi pressure fuel pump not working
Receive 12-15 volts DC from de ECM (pump disconect ) when pull start, but 0 when pump is conected. If i plug the fuel pump on a battery the motor run good.
Is the ECM bad ? is the fuel pump drawn too much Amp and made the ECM cutting the power ?
what tests i can do to find the problem ?
A new OEM fuel pump is 1100,00 $ Canadian and ECM about the same
Sorry for the bad english
Thank you !
alldodge
Welcome
Don't know much about the motor but the fuel pump is turned on by a relay. The ECM does energize the relay by applying a ground to one side of the relay coil. Check the relay and fuses
Sylva-Ranger
Welcome
There no fuses and no relays on this particular manual start motor.
Acording to wiring diagram, the ECM direcly apply power or ground to the fuel pump.
Sylva-Ranger
Do you think the put can be good for run on a battery but not by the ECM ?
