I've got a 98 model 25 hp 2 cylinder electric start tiller motor. Yesterday I backed it in the water and pushed the starter button and the button didn't reset - it stayed depressed. I then saw that the bare ground "cable" that goes from one of the starter bracket nuts to the screw by the gas line intake was red hot. It then caught a wire on fire and I had flames. I was able to put it out quickly thank goodness. The small ground cable had burnt in two.
Got home today and made another ground cable. After a few seconds of cranking, the cable continues to get red hot. Also, I noticed that the starter button didn't spring back out once I pushed it the last time. Looks like it had come out of its seat inside the cowling again even after I thought I had fixed it.
Could this be a bad battery? Could it be that the worn out ignition switch is causing it to get hot? I have no idea what's going on!!! Please help.
