25 hp blowout The
Ktoe
I have a 1468 Lowe v Hull and a 1998 25 hp mercury 2 stroke. The transom on my boat is 20” the shaft on the Mercury is 19.5, which puts the cavitation plate about 1/2 inch above the bottom of the boat. The standard 13 pitch prop that came with the motor does not seem to like this as I experience blowout when I accelerate, just before it planes, also in the chop if the waves get very big. At full throttle with a full load I’m running 25 mph and 5600 rpm. Im wondering if getting a prop that’s happy a little closer to the surface wouldn’t be the best solution to this problem? What would you suggest?
Sea Rider
Does motor sits perpendicular to water level (90deg) with deck weight well distributed and combo riding on flat calm water cond when experiencing this prop blow out and revs coming up ? If so means that motor sits too high on transom, those rebadged Tohatsu motors likes to ride while water flow skims right under upper small plate, if flow at plane passes near lower AV p'late will experience so. If trimming motor away from 90 deg, prop will lose its best prop thrust.
To determine, plane the combo out, pull head out transom while sitting inside aft deck and check at which lower leg height is flow passing by, then will know what's really happening at back transom. Once you know can work from there...
Happy Boating
Ktoe
The motor is trimmed 90 degrees to the boat with the cavitation plate in the froth with the boat fully loaded and balanced and on plane.
ahicks
If you have a local repair shop, you might ask them about having your prop cupped. That will bring the rpm's down a bit, and resist venting a bit at the same time.
flyingscott
Pit up a pic. I would expect a Mercury 25 hp to measure around 23" for a longshaft. 1998 would not be a Tohatsu motor.
Sea Rider
Issues to have into account
-Doesn't matter if it's a Tohatsu, Merc, Yam or any other motor brand, all have upper and lower plates.
-On a dry installation (sitting a motor on transom) does't matter the height the plate sits with respect of rear hull, when hull at speed climbs out of the water it's a different story. There are only 3 possible situations : Back water splashes out/over transom, spot on lower leg/transom match, prop aeration achieved at different lower leg heights while motor sits on transom.
-If boat rides 25 MPH at 5600 wot rpm it's impossible to have a spun hub.
If wanting to solve the prop aeration fast, check at which lower leg is water flowing by as suggested. Max wot revs for that 25 HP must be 6000 rpm, if so, motor is 400 revs off when fully loaded. Do you always, usually go boating fully loaded ?
Happy Boating
Ktoe
Happy Boating
I’m taking the boat out tomorrow and will check where the water flows when the boat is up on plane as suggested. As to a full load— most of the time I fish with a friend pluss trolling motor and battery, so full loaded for a 14’er (500# not counting motor, gas, and hull weight)
QBhoy
Is that your engine sitting at its lower position ? If it is it looks a little highly trimmed out for your application perhaps.
Ktoe
A photo of the motor, it’s a 25hp with 15 decals.
As as to the trim position, I moved it one pin closer to the transom and lost 2 mph and it pulled pretty hard to the side. It did improve the blowout problem slightly, as it buried the prop a little deeper, but didn’t eliminate it.
ahicks
Moving it in one hole may be part of your solution. 2 mph in top end not worth the issues caused by it blowing out too easily. That trim tab above the prop can be used to off set that torque you're talking about.
WesNewell
Even though the first photo shows the av plate in line with the bottom, I have a feeling it's not in line with the hull, just that the stick in touching the back of the hull. The second photo seems to support this. Move the engine tilit pin in one or two holes to allow a more 90 degree relationship between engine and hull bottom and test it. Engine mount height looks ok. As it is now, I would expect some porpoising at wot. aligning the thrust wiih the hull bottom will eliminate most of that.
jimmbo
Your boat, being a Tin boat, likely has a pronounced keel running down the length of the hull. If so, then the AV plate needs to be even or below that, even if it means being an 1 1/2" below the bottom of the boat.
Can you provide a picture from the side of boat at the transom that is level(not tilted up or down) and is taken at the level/height of the boat bottom? The side shot you currently have is taken too high to be able to accurately see what is needed to be seen
Sea Rider
Some issues not clear :
That's a L shaft Mariner Motor along a L transom height ?
If motor is trimmed to 90 deg, hull planes parallel to water level and deck weight is evenly distributed on deck will dare to say that water flow at speed is passing somewhere 2 and 3 which is the aeration zone, the closest to 3 will give worse prop aeration, insufficient water bed height for prop to bite spot on and achieve top prop thrust. Check lower leg configuration to understand plainly.
Forget all about AV plate height with respect to middle rear hull, a picture doesn't sat much at all, it's just a dry installation reference. In real boating world you need to match whatever shape the water flow exiting middle hull at speed has to skim right under the small upper plate (1 ) bluish dotted line) by rising or lowering the motor on transom, once there lower leg will achieve the best water bed height and top prop thrust in most water cond along nice close turns at speed.
Post at which lower leg height was water flow passing by when visually tested to check what's really happening out transom to go from there. If can post a nice pic much better..
Happy Boating
Faztbullet
Between 2 &3 is where you want water line if you have a runner in middle of hull. If no runner 3 is where you want it as 1 is too deep. Also fill in the holes in skag with epoxy as they can cause a disturbance in front of prop.
Here is video to prove the point, watch where water flow is..
https://www.youtube.com/watch?v=Y9lZ2Ry7bYw
QBhoy
It’s clear from picture that your trim pin is in the high trim position. Tell better about engine height with a better picture but if you running like that, it’s half or all of your issue.
Sea Rider
Know the guy his name is Stu, he's from Australia, have talked the guy a few times..
Will entirely disagree on that one, with that setting on choppy windy, wavy water cond prop will produce excessive aeration, only good to run on flat no wind water cond. OTOH boater has made no tight turns at speed at all, sorry video means nothing, to duplicate...
You guys should test any "Under Powered Motor" by playing on all 3 heights while motor sits at 90º and combo runs parallel to water level with weight evenly distributed on deck and check what does each setting on choppy windy water cond and at close tight turns at full wot, who has done so under proven water test NOBODY on this forum.
Let boater report at which lower leg is water flow passing by....
Happy Boating
