littlemess
- Aug 25, 2007
- 48
Please Help, I'm a very novice mechanic!..... 1979. 25 HP Evinrude with electrical issues. Starts and runs like a champ sometimes, then the next time... no spark at all. Swapped out the power pack with a similar Johnson, ran good then died again. Someone suggested stator coils. I Pulled the flywheel only to find the stators (looks like a magneto to me?) is a completely sealed unit (encased in a big green ring of plastic). Cleaned it up put it all back together. I did change a ground wire which looked bad (cracked insulation & some corrosion). It started right up ran great. Went to start it up 2 hours later... No spark!!!!...... No start.
