itsarunner
- Jun 18, 2010
- 14
I have a 25 hp Evinrude and have a lower drive assembly question. It is a late 60's. When placing the detent spring and two balls inside the prop shaft and placing the shifter dog on the shaft, is there a certain way the dog should be orientated on the shaft? Inside the shifter dog, there are the spline groves and on inside there are two deeper grooves perpendicular to the spline grooves. If I place these grooves where they line up with the detent balls, it is difficult or impossible to shift. It was like that when I bought it. These two grooves do not appear to be wear etc., they look machined and the rest of the assembly looks to be in really good condition.
Should the detent balls be aligned with these two internal grooves or not? Hope this makes sense and thanks for any help.
