goblerblaster
- Dec 26, 2011
- 180
I have a 1995 Evinrude 25 hp that I an trying to replace the prop seals on before selling. Does the prop bearing carrier unscrew or just pull out with a puller? If it unscrews- which direction do you turn it to unscrew it? I broke a carrier on an old Merc one time tapping it with a punch trying to get it to unscrew, so I am trying to be extra careful on this one. Thanks for any suggestions in completing this job.
Also, I just put an new impeller on this and have a lower unit seal kit. I read in another post that you should change the shift shaft seal when changing the prop seals, Is that something I can do without dropping the lower unit- again- once I get the bearing carrier out of this thing ??
