Riverman128
- Aug 10, 2007
- 40
Model # 1025205
Serial # A173598
Gentlemen,
My engine is not firing on the bottom cylinder. I replaced the plugs and the wires. I switched the coils and the bottom cylinder still not firing. Both coils ohmed within specs. Both the stator and the trigger ohmed within specs. My manual does not outline a test for the switch box. I tried ohming both the stator leads and the trigger leads coming from the switch box. In both cases I get no reading (open circuit). This may be normal for the switch box? Is there a test for the switch box? Any ideas what my problem is or what I should test next? Thanks for any and all help!
Serial # A173598
Gentlemen,
