25 hp impeller & key ** Update*
Alumarine
Hi I'm in the process of replacing the impeller in a 2001 Johnson 25hp long shaft.
I noticed the impeller key looks a bit odd to me as well as the inside of the impeller.
Anyone have an opinion?
Also, when removing the impeller housing the drive shaft moved up about 3/4" of an inch. Is this going to cause me trouble? I notice the prop doesn't ratchet in gear.
tashasdaddy
Re: 25 hp impeller & key
i've never seen one like that.
Alumarine
Thanks, so I guess I should order the key as well.
Alumarine
Re: 25 hp impeller & key ** Update*
Well it turns out that is the way they are supposed to look.
I picked up a Johnson/Evinrude impeller with key # 395289 and they looked just like the ones that were in there.
Gary H NC
Thats the way my new one was made...had me all confused but it is still pumping good..
Took me a few minutes to figure out how to put the key in there..:confused:
Alumarine
Yea, when I took it out it sure looked like something that had become mangled.
