25 HP Johonson 96-97 won't run without choke
JIM4475
My motor will crank and run as long as I keep the key pushed in (choke on), cleaned the jets, that didn't seem to help. It will run for a few seconds after the choke is turned off, and if I push the choke on it will pick back up. Any suggestions on what to check?? Thanks:confused:
HighTrim
Re: 25 HP Johonson 96-97 won't run without choke
What is your complete starting procedure, step by step?
It does sound as if the carbs jets/orifices are gummed up. How did you clean them?
JIM4475
Just purchased the boat from a neighbor. I ordered a carb kit today, we pulled the jets and they were gummed up, but I plan on compleatly rebuilding the carb this weekend. I talked to a local boat mechanic and he said that was the problem. Thanks for the info.
