25 hp Mariner starts, runs for a while then quits
Miket978
My 25hp mariner starts fine runs a short while (5 mins) then quits. I can restart almost immediately again then it dies more quickly. The motor seems to die when the you change rpm either in neutral or in gear.
A bit of history. this spring I replaced the bulb on the fuel line after it began to come apart in the fuel. ( ethanol break down?) it fine particles of rubber plugged my fuel filter , and it had to be replaced.
Is there any chance the carbs could be the issue? Hey were cleaned last year.
Thanks
Mike
