I was having some problems with my Starter not working on my 1999 25 HP merc. <br />( serial # 06765886)<br />I had the starter rebuilt last year by a local outboard shop. I towed my boat in today after storing it all winter and asked them to fix the starter again. I had used the motor only a about 6 times last year and the starter quit after one day of use. The motor ran well with lots of power but I had to pull start it. The last time I used it the elec starter did not work at all so we had to pull start again. It had trouble starting this day but ran fine after getting it going. The boat was then stored for the winter.<br />THe shop told me that the first thing they do is A compression test and that one cylinder was around 80 psi. The other was ok. They also told me the Armeture? had to be replace on the starter.<br />SO he told me the piston was scored and needed to be replaced and if you do one the cost was minimal to do the second one. Cost with shop time (8 hours)was around $1000.00 can.<br />I told them to not do the repair.<br />I was reading the manual that says after storage the motor should be warmed up before compression testing due to relaxing of the rings. It does not sound like they did this? Would or could the piston be scored or how would he know unless you pull the head and see??<br />I bought the motor and boat last year form a sick elderly man who only used the motor one season. He was a fastidious person with his boat as I am. Carefull oil mixing. How oculd such a new motor have a scored piston?<br /><br />HELP!!<br />ANy opinions?<br />Hugh
