25 hp merc cooling
rooster1
when running theres a steady stream of water coming out a hose by the head theres also a little bit of water coming out the back of the engine out of some little holes does this sound like proper cooling i didnt know if the water coming out of the rubber hose was correct
bgbass.1
Re: 25 hp merc cooling
yes it sounds right the water is suposed to come out of rubber hose and you will get a little from the exhaust.
mike
bgbass.1
oh yea they call that hose the tell tale if you dont see a good stream of water coming out then you know you have a problem with water pump or a blockage. hope this cleared up your concern
mike
