25 hp merc elec start question
floatmiboat
Hi,
I have a 97 merc 25 hp electric start with remote controls that I've had various starting problems with. Recently I went out fishing and when I went to start it up I got nothing if I turned the key, the battery is good, the starter and solenoid are fine and I read 13 volts between the battery ground and the large red terminal on the solenoid but nothing to the small red terminal when I turn the key. It starts fine if I use the pull cord with the key turned on and if I jump between the battery and the small hot solenoid terminal it will turn over fine too. Does this sound like a bad wire between the ignition key and the solenoid or could something be at fault with the ignition itself? Thanks
floatmiboat
Re: 25 hp merc elec start question
Have you checked the neutral safety switch.
No, I had assumed that since it starts fine with the pull cord that the neutral safety switch wasn't an issue?
floatmiboat
Is the neutral safety switch located on the engine or in the remote control? I think it's the little square black box closer to the rear of the motor from the solenoid?
