toocheaptosmoke
- Jul 2, 2006
- 4
I have a 25 hp. merc that is a 1994 i believe. the motor has always started fairly easy and has good power. one problem is, it hesitates when you try to get going from a slow speed. after a couple seconds the power kicks in and it takes off. it doesn't bog, it just doesn't want to go. another problem i noticed is the plugs are different colors. the bottom runs very clean, almost too clean for my liking, but the electrode doesn't look like it's running lean. the top is always dark brown to black. i did a compression test and both cylinders are the same, the top might have a pound or two more. another thing i noticed yesterday is a high idle after a good run. i have experience with quad and snowmobile engines but outboards i'm not as familiar with, so I appreciate any help.
