25 HP MERC
daniel _49
HOW DO YOU REMOVE THE LOWER UNIT FROM A 2001 25 HP MERCURY - TO GET TO THE WATER PUMP - I CAN GET THE LOWER UNIT TO DROP DOWN BUT CANT GET IT OFF I THINK THE SHIFTING ROD IS HOLDING IT
SpinnerBait_Nut
Re: 25 HP MERC
Daniel, wrong place to ask and I'm sure it will be moved to outboard engine question section.
Hooty
Re: 25 HP MERC
You're probably right. Where does the manual say to disconnect the linkage?<br /><br />c/6<br /><br />Hooty
