Re: 25 johnson drive shaft
Thanks to RPJS,OB,G Dane for all the replys<br />but let me give you a little more info on this motor <br /><br />1. the motor sat up for two years<br />2. i bought it<br />3. i rebuilt the lower unit complete<br />4. gears were crack where the brass goes<br />5. changed the gears Brand New Gears<br />6. had lower unit sand blasted inside and out<br />7. installed new seals,gears,gaskets,and lube<br />8. went fishing!<br />9. drive shaft broke at top spline.<br />10.installed new shaft after having gears blacklighted for cracks<br />11.went fishing (brand new Drive shaft)($300.00)<br />12.shaft broke again at bottom spline.<br />13.here i am NEED HELP<br /><br />i will check the power head fore alinement and let you know the out come thanks again.<br /><br />P.S. I did not hit anything first time or second time i was in open water both times.
