255 mercruiser runs rough
gjr711
I have a 1977 mercruiser 255 inboard, this year it started great but after long runs it stalls and wont idle but after a short time to cool off all is back to normal, i have tried everything i even bought a new carb it got a little better but still wont idle
Re: 255 mercruiser runs rough
Ayuh,... Is the fuel pump Delivering,..??
Is the tank giving it up..??
gjr711
the boat will run great all day wide open throttle but when its time to idle no go
Ayuh,... Time to diagnose,...
When it Stalls,.... Pull a few sparkplugs,+ LOOK.....
Is there Fuel,..??
Is there Fire,..??
gjr711
it does seem to be loading up with fuel but what could make this happen only when it runs for a while then is fine in just a few short minutes
Ayuh,... My WAGuess is the Carb or it's settings....
But I'm not there to LOOK...
gjr711
its a new carb and idle mixture screws are adjusted just fine . im starting to think maybe a float adjustment? just that is wierd when you first start it up it can run at an idle for so long. take it for a spin then bam its back.
John3
Had a similar problem. The coil was overheating. Ran fine again when the coil cooled.
Quadruplecccc
Did you replace plug wires? I just had the same thing happpen and swore my plug wires were new enough to not be the problem. I was wrong! They were arcing somewhere.
Coil ? Could be! Gotta check it all!
Quadruplecccc
Oh yeah. Did it happen to backfire on you? If so you could have blown out the power valve in carb. This will kill your idle.
gjr711
tried new coil wires etc going to look into the carb again
