Re: 25hp evinrude will not spark!!!!!!
Hi Seanymph 18<br /><br />You can try the easy ones first. The wire from the kill switch ( Yellow/black colour ) on my 25 Hp once wore through just below the carbs, and sparked to ground, killing spark. Try to locate and follow that wire, it is not routed same way if your have remote or tiller. Disconnect it at next plug from powerpack, which is the black box, sending current to the two ignition coils. If spark comes back you have a bad switch or a short somewhere.
