25Hp Johnson (2000) - Water Flow & Relief Port
Deano_G
G'day Folks.
Picked up a new to me 25Hp Johnson (M.Y 2000, J25RLSSE), and gave it a run on the weekend. Everything appears to be in order (start first pull, pumps good water out indicator and exhaust ports, runs well [24knts on a 12' tinny :)] , didn't seems to overheat), however during use I noted water coming out a port on the front of the motor below the tiller handle (pic attached). Only happens from ~50% throttle and upwards.
I had a look through the workshop manual and couldn't see anything obvious that speaks about this. It appears to be an engineered feature as opposed to a random leak point. Can anyone offer any clarity, is this normal behaviour, is it some type of overflow / relief port?
Tks, Dean,
