I have a 1974 25hp johnson outboard (25R74) that has been running fine for over a year. In the last month, I have replaced the prop and changed the plugs. Engine was running well. All of a sudden the engine starts to cutout (misfires?) at high or maximum rpms. Runs fine at lower rpm. Idles and starts well. Water pump appears to be working. The only change before this happened was new fuel (and oil).
I have noticed that the bulb on the fuel line does not compress. Always inflated and hard to squeeze. Checked valve on fuel line that enters engine and when open allows fuel to flow. Have tried to squeeze bulb at high revs when engine was cutting out but did not fix problem.
Any help with this will be much appreciated. Thanks!
