25Hp Stalling
springbok
Hi all, I have a 1988 25Hp Evinrude Outboard. I'm getting it ready for the summer, so I decided to run it in my driveway with the flusher ears on it. It runs good at idle and when I give it throttle it revs high and sounds good like you would expect. Then all of a sudden it boggs out. If I decrease the throttle back to idle when it boggs it will stay running, if not it will stall. I rebuilt the carb a month ago and took it apart today to recheck it and it's fine.<br />I pulled the plugs to check them and they were wet. <br />Any ideas? Thanks...
Cricket Too
Re: 25Hp Stalling
Springbok.....First off it's not a good idea to rev a motor above 1500-2000 rpm on the muffs. Secondly how old is the gas in the tank? Also when you rebuilt the carb did you soak it in a parts cleaner for a while and then blow everything out with compressed air before reassembling? And did you do a link and synch after re-istalling it. You really can't tell what it's really doing unless you run it with a load on it in gear, you should try to get it on the water, maybe have to wait a month or so.
springbok
Re: 25Hp Stalling
I did soak the carb in cleaner and blew out all the ports. What is a link and sync?
OBJ
Re: 25Hp Stalling
Springbok.....a sync and link gets the timing in tune with the throttle plates.<br /><br />If you run the engine at high rpms out of the water, the engine could run away or do itself some damage.
