270 leg ,AQ125a prop
-JR-
Have a 1984 bayliner 18.5 haul and the 14 x15 prop just revs the engine a live high and so does the 14 X19 prop.
Anyone run a 15.25 x 15 prop on their 270 leg.....will it fit ? If it will maybe a 15 X 19 would be a better choice as I only use it as a fishing boat . Just going to A to B
jerryjerry05
What RPM'S are you getting with the 15P
​Is the prop a Volvo prop?
These Volvo 125s need a Volvo prop.to produce the HP and perform the way it should.
-JR-
around 5500 rpm with the 15 Pitch and 5000rpm with the 19 pitch
jeffnick
If your propeller shaft is threaded you can use this long hub propeller, or a similar short hub prop.
SOLAS Amita 15-1/3 x 19 LH 8812-153-19 propeller
If your shaft is not threaded you'll need to fit a short hub propeller - or - tap the shaft.
