27PC water tank repair
alldodge
1994 27PC and the water tank is leaking into the cabin bilge. Just started this season and leaks down to about an inch from the bottom. Called tech support and they informed me that I would have to cut through the aft cabin floor and pull it out from there. After pulling the cabin apart I'm looking into other options. I can cut through the top of the tank, cut out the baffle and put in a blatter tank to fill most of the original tank; put a 10 to 15 gal tank on the port side next to the battery, or put another on the starboard side. Has anyone had similar issues and fix a simular problem?
alldodge
Re: 27PC water tank repair
Bump, really know one has ever had a water tank problem?
