teleman360
- May 30, 2006
- 4
My 1993 28 spl has a split gear case at the lower unit. The horizontal seal is leaking and water is getting in. The low unit fluid is like chocolate milk after 2 uses. It also drips about 1 oz of fluid per week. I believe the split gear case seal need replacing???<br />If I leave the o/b mounted on the boat, can I remove the 6 bolts at the gear case and change the seal? Will the shaft, bearings, other seal, etc. stay in place when I remove the lower part?<br />Thanks!
