290 outdrive woes
Ed Polguy
First trip this season, port side out drive slipped out of gear, tried to re-engage , no luck.<br />Got back to the marina, unit shifted into gear fine, but started to whine, then the engine stalled as if something had seized, now engine won't turn over , not a starter problem , engine is not seized. <br /> So, I'm guessing its a a problem in the top end of the out drive, or is it possible that its the gimbal bearing.<br /> I did do something , that might have precipitated the failure, I unlocked the drives to lift them up to paint them, and forgot to <br />lock them back down, so when I went to back into the slip, they both lifted out of the water. <br /> Ahh @@##$%#$^!!!!, what now!! :mad: <br /> Any Ideas ??? <br /> Thanks Ed
Re: 290 outdrive woes
Pull the Drive,+ Have it Torn-Down,+ Inspected...................
