ONERCBOATER
- Oct 11, 2010
- 536
well go figure after years of being almost rock free, i pony up and get a solas SS 9.25x 10 to replace my 9.5x10 stocker on the ol 15hp johnson (1983). Overall a bad choice i guess..... top speed dropped, rpm dropped,
and then....gasp.... yesterday out with Mom and my son i find a huge rock and bend the heck out of the edge.
So my response was to use a cresent wrench to sort of straighten out the edge and minimize the wrinkle. and just use low power to finish fishing out the day.... (yeah i know not so good for lower end as not balanced)
Anyhow a day later much less mad... I looked over the prop and noted that if i removed 1/4" of the leading edge and tips after hammering out the wrinkles I would have a smooth working propeller. I can ballance it well as I have prop ballancers for large scale rc plane props that are large enough to do the job and very sensitive. And i can assure that the profile and shape is the same on all 3 blades using the one good blade as the shape to copy.
the question is... while i am pretty sure that removing material will raise my rpm (likely a good thing for this engine) will losing that much blade area effect the thrust greatly? or should I just give up and buy a lower pitch aluminum solas and try to be happy, as i can't afford to spend another $125.00 on a prop with xmas so close.
Any constructive input would be appreciated.
Sean
Sean
