fairshopperguy27
- Aug 22, 2012
- 127
Trying to find out what year this engine is block#3915991 it came out of a 1989 but I suspect it may not be the original engine, the coupler is smoked, I removed it and it is not the modern triangle syle one its the other circluar kind with several bolt holes. I have a 1997 3.0lx cracked block # 14097080 and am wondering if I can just swap over the Flywheel, coupler and bellhousing? Also will swap the front motor mount if the rear is possible. Already swapped the electronic ignition which is working great. This will be going into a 1997 Bayliner Classic 1950.
