3.0 GS Carb or Fuel Issue
tvogz
Hey guys. Just got the boat back on the water today after replacing the gimble bearing, aligning the engine, and both bellows. After warming up the engine to temp I pushed the boat to WOT. Interestingly, I wasn't able to achieve the same 4600 RPM that I was able to a few weeks back. Somewhere in the neighborhood of 4200 now and this is at about 7/8 throttle. If I push the throttle all the way down, the RPMs actually drop a bit. This is a 2001 3.0 GS MEFS. The carb was overhauled last season, and I probably have less than 10 hours on it since then. The idle mix was set a few weeks back with an external tach. After that I would get hesitation when accelerating so I adjusted the power valve with feeler gages. This seemed to move the hesitation further up the RPM range. I attempted to adjust again today, this got rid of all hesitation, but the dropping of RPM at full throttle persists. Am I on the right track?
alldodge
Probably lack of fuel.
If you go WOT for a few minutes, then slow and shut the motor down. Pull a couple plugs and see if there showing a lean burn. Don't want to do much idling before checking
Would suggest installing a fuel pressure gauge to see if the pump is keeping up
tvogz
Just to close the loop on this one, I vaguely remember adjusting the throttle cable before reinstalling it after adjusting the accelerator pump. This was all just before I found the bad bellows so it slipped my mind. Anyway, a quick adjustment of the cable fixed the issue. It must have been adjusted to the point where the flappers went last vertical.
