3.0 GS Fuel Return Line?
kc6ape
I have a 2003 3.0 GS with a Holley Carb. I pulled off the exhaust/intake manifold to replace a broken bolt. Putting everything back together and my engine has a clear plastic line going from the top of the fuel pump to somewhere on the carburetor I know I removed it however there seems to be no place to reinstall it on the carb. there is a port next to the electric choke however there is no way to attach the line, I can't find any parts break down on the Holley carb showing the choke side of the carburetor does anyone know how this line is supposed to attach to the carb.? Thanks Baffled in Cameron Park
Maclin
Re: 3.0 GS Fuel Return Line?
It may go to a fitting on top edge of the flame arrestor...
Don S
Perhaps you could include the dash letter following the 3.0GS. That works, 2003 doesn't.
kc6ape
Sorry about that Don, it's a GSP-C. Thanks again
kc6ape
Thanks Don I found it! I had to stand on my head and look up underneath the top of the carb it was a snug fit.
Don S
Just when I found a picture to show you where to look.
aerobat
Master Chief Petty Officer
this line provides the fuel floods the carb and not the the bilge should the pump fail, correct ?
