3.0 knock
trebot
Have knocking sound coming from rear of engine. Gets louder the quiets down. Motor runs fine except for knock. Good oil pressure and temp. Pulled distributor, everything looked fine
Ran motor with valve cover off. Every thing looked good, good oiling.
Don't think its a rod knock as the knock comes and goes.
Could it be the outdrive and telegraphing the noise?
I DON'T want to pull the motor, but I'm at a loss
could be coupler is going, could be u-joints going
when was the drive last off and alignment checked?
trebot
Thanks. Am going to pull outdrive and service (u-joints water pump)
Can coupler be replaced without pulling motor?
No, coupler replacement requires motor removal
