BradJCoker
- Mar 16, 2021
- 3
I am hoping someone can help me out. I have been working on a restoration project on a 1988 Sea Ray. The engine was seized when it arrived. Long story short after emptying the water/oil from the oil pan replacing all gaskets seals and cleaning it up down to cylinder level. It all came back to life.
I know the engine drain plugs are on the port side the guy I got the boat from said he lost a plug that was on the starboard side toward the back of the engine. When the motor is running the hole spits water. Is this normal? If so what type of plug goes in the hole the part of the block has a dual hole a horizontal threaded hole what looks like a lift point and a hole that faces up and that is where the water spits from when running. Any help would be great.
