recently noticed my exhaust manifold gasket was leaking and causing engine to run rough. I then noticed water in my oil.changed oil and mani and riser gaskets next day . seemed to run fine for about half an hour. then noticed a little bit of water was still getting into oil . thought maybe it was head related.took mani back off and exhaust ports had water in them . tested manifold not sure if it is leaking enough to p[ut that much water into manifold unlees it maybe leaks a ton when hot (hopefully) boat ran like acharm all summer and then this . can anyone please help?
