TheJack73
- Jun 1, 2020
- 2
Hi Everyone
I have done some searching on the forum but not sure if I have found anything that matches exactly my problem. I have a 96 SeaRay 175 with 3.0LX of course and I have water in the bilge. It's been leaking for a while, not much, pump would empty the bilge in about 20 seconds and it is very sporadic when it was leaking but today I made a discovery. With about 1/2 inch water in the bilge enough that the pump couldn't pump anymore out I took engine cover off just to take a routine look and I could hear water trickling in. I found that it looked like it was coming in around or above the water inlet for the engine. Now hear is what I am trying to understand. I had the drive trimmed all the way down as the kids were jumping off the swim platform. I noticed that if 2 adults stood on the platform I could hear water trickling in and could see it running as said around the engine water inlet, but if nobody is standing on the platform then I couldn't hear anything. So any ideas on what could be causing the issue when more weight is on the platform? Also another bit of information when pulling our 3 man tube no issue with water in the bilge.
Thanks for any help or suggestions on what to check.
