3.0 merc year?
thumpar
Post a serial number. There are a few people here that can look them up.
Zhulkk
What one would it be?
dozerII
It should be on a tag above the starter on the block just below the head where the flywheel cover bolts on.
Fun Times
Okay found it! 816978C and below it is 22241
Hi there, that doesn't quite look like a mercruiser serial number. Typically the number may start with a C816978 or a 0C816978 but not end with one.
As an example, If I change the number you posted around a little (0C816978) it comes up as an 1989 Alpha stern drive.
Have a look at the following link for a visual of where the engine serial number should be located. http://forums.iboats.com/forum/engi...n-drive-and-engine-serial-numbers#post6661412
