While out on my 89 sea ray 160 br that has 3.0 mercruiser with alpha 1 outdrive, the gauge for volts shows right at 10. I turned the boat off and almost killed my battery trying to restart the motor about an hour later. Luckily I had a second battery and jumper cables that I used to combine for starting power. What should the alternator be producing as for voltage? I am worried that my alternator is not creating enough volts to charge the battery when running. Also, if it isn't producing enough voltage, can I do something as for maintenance or cleaning that will increase this?
