3.0 Mercruiser block/exhaust drain hose o'rings
1ARUNEM
My 2001 Maxum with 3.0 Mercruiser has the two blue quick disconnect hoses for draining the block/exhaust. One of the o'rings on the 'barb' that they snap onto has failed.
Ideas on where I could find the proper size replacement o'ring?
Thanks in advance!
1ARUNEM
FYI, for anyone in the future, the part number appears to be 25-62702 1 ...
My local dealer says they have them in stock.. $1.30 ea ..
thanks..
Ayuh,..... 1 of Merc's frozen busted block systems,......
Pull all that junk off, 'n use 2 brass pipe plugs, 1, 1/4" in the block, 'n another in the manifold,.....
Scott06
Bondo is steering you straight here. To put a "easy winterization" system on a 3.0 is folly by mercruiser. Two plugs and in the size boat a 3.0 is in very easy to get to. You HAVE to see how much water is coming out of each port to properly winterize.
