3.0 mercruiser hard start won't idle looses power
sec8cord
We have a 1987 Sunbird with a 3.0 Mercruiser. It was hard to start first time out this season. Fiddled with the timing. Started great. Then slowly lost power after getting out of water started pinging noise. Did that a couple of times then ran okay at almost full throttle ( for 15 miles) . Turned it off and did not want to start. Backfired twice out of the carb. Finally got it started did not want to take off. Finally got power went to almost full throttle ran okay all the way home ( 15 miles or so) idled down to pull in dock and died did not want to start again. Don't want to Start, Idle, and has no power. There is gas in the filter going to the carb. Any ideas??? HELP. We have changed the Cap, Rotor and plugs. Any suggestions??
badass
Re: 3.0 mercruiser hard start won't idle looses power
check for water in your debris or water in your fuel it sounds like you might be due for a carb rebuild
sec8cord
Well, we took the boat to the shop. One day it was done. Fast... They said the timing was off, point setting off, carb reset said that it still idles a little rough... Thinks we may have a low cylinder in the motor.... Can anyone tell me what this means??? Thanks
