Having an intermittent issue with the tilt/trim on my 2001 Maxum 185 SR bowrider with a 3.0 and Mercruiser outdrive..
Trim up works fine always.. Intermittently the 'down' trim does not work. When depressing the switch on the controls, I hear clicking but no action or motor running.. I can hit the 'up' trim a time or two and then the 'down' will usually work.
Sometimes down works fine but issue seems to be getting worse and don't want it to fail completely and get stuck with outdrive up.
Thanks in advance!
Thanks in advance!
