Hi I have a ‘93 Sea Ray 170 with the 3.0. So when I drop the boat in the lake and start it, I prime and it starts but only with throttle. And I have to continue to do so until it warms up a bit, so I have to sit at the landing and let it warm up enough to idle to shift it in gear to get out of the way. My idle when warm and in gear is roughly 500-700rpms, it depends. I did replace the cap and rotor, wires and plugs. Carb seems to be okay, and the fuel mixture screw I set “properly.” Is this normal? And another thing I notice, it appears to have 20-25psi for oil pressure idling and 35-40psi at WOT. Is this normal? I bought the boat over the winter and haven’t changed the oil as it was changed during winterization. Should probably change it.. which leads to 10w30 oil like it says on the cap, or the 25w40 as Merc recommends?
