RR_Maillet
- Jun 26, 2004
- 8
I have a boat that has sat for about 6 years and I changed all the fluids and plugs and tried to start it. The celiniod only clicked so i thought that the engine was stuck and had to be freed up. So I used mystery oil in the heads and on the cams and turned the engine, although it did not seem to be stuck, it turned fairly easily. So then I tried to start the engine again and it made the same click, click noise. So now i believe that it is the Starter which is no good. I am going to try and take the starter out and have it looked at. Any help/tips about my problem would be great. And how hard is it to get the started out. Is it the starter? or the celinoid? Thanks guys.
