matt167
- Sep 27, 2012
- 4,174
I need a distributor with locked timing to run fuel injection on an old 153 that I’m putting in my rat rod ( 1970 Mercruiser 2.5 )
First will the 3.0L MPI distributor fit? And second. What kind of trigger does it use? Hall effect or optical?… the reason is I may go down the turbocharging rabbit hole as a manifold is cheaper than a header flange to build headers, and way cheaper than a built set of headers
