My 1986 3.0 OMC Cobra makes an intermittant clattering, loose bearing kind of noise at idle. Sounds like it's coming from the power steering pump ...or maybe the main water pump(they a relatively close together) My guess is it's my power steering pump. Water pumps usually squeel when their in need of replacement.<br /><br />The noise goes away when I accelerate and drive. At first I though something was loose, but I don't see anything loose.<br /><br />If it's my power steering pump, should I change it? It seems to work fine. What are the risks of just waiting...Can it jam and fry my belts? Or will I just loose power on the power steering...which is no biggy cause it can easily steer without it (16 ft bowrider).
