3.0 omc engine coupler
yellowbiker
Hey so I have. A 86. Omc with a 140 hp. Engine that was replaced 3 seasons ago with the newer flywheel. I fairly sure my coupler has slipped. Squeakes will engine runs. Just ran the engine Alingment. And is pretty good. It still squeaks and the outer edge of the coupler where it meets the metal is fairly hot to the touch.
I assume there here is no repairing this. There seems to be little or no info on this any help befor I drop $$$ and time would b great. Thanks
HT32BSX115
Howdy,
Welcome aboard!
You might want to post your model number since there was 2 very different models available in 86 model boats. Cobra and Stringer.
It could be any of the following:
302AMKWB 1986
302APKWB 1986
302FTHRCOM 1985
302SPHRCOM 1985
302STHRCOM 1985
If you don't know or cannot find it post a picture of what you have.
Regards,
Rick
kpg7121
Yes it can be repaired. If it's a Cobra you'll have to pull the engine. That part will run you probably at least $400. I won't comment on if it's a Stringer. Don't know enough about them.
Cobra uses an elastomeric coupler held to flywheel/crank with studs. This requires yearly check of alignment, and greasing the splines
Stringer used a solid steel puck with splines. No check of alignment
Repair is by pulling the motor and replacing.
