3.0 plugs and wires
Nateali38
91 bayliner 3.0 mercruiser alpha 1. I am looking for something that shows which wires should go on what plugs. Also is plug one considered the forward plug or the aft plug on the engine? Any help would be appreciated.
JWebber
Re: 3.0 plugs and wires
See pic!
Don S
Here is the firing order and layout.
One thing you MUST do, is to verify that you are on #1 TDC on the COMPRESSION STROKE. if you are on the exhaust stroke, the rotor will be pointing 180? from where it should be.
Easy to verify, read this http://forums.iboats.com/showthread.php?t=427081
attachment.php
