88 mercrusier i think. anyhow what is the correct wiring to the coil. i have the purple/yellow wire and a yellow wire with a piece of purple tape on it. I would assume that the original wire was replaced and that was the way of tagging it. i know the purple/yellow wire goes to the starter. am i correct that the other wire goes to the alternator if so where on the alternator?
the big issue i am having is it will crank and start but as soon as i let of the key it dies. what is causing me to lose fire after i let off the key? Its like its loosing its constant power not sure
thanks for any help
thanks for any help
