3.0 to 3.7 engine swap
Tommy2082
Hi i have a bad 3.0 mercuriser. I aslo have a good 3.7 mercrusier and outdrive. My question is is it possible to swap it out without having to replace the gimbal housing as well. Both are alpha outdrives. Thanks
nola mike
Yes, you'll need new motor mounts. Now prepare yourself for the onslaught :pop2:
Bt Doctur
only if the rear motor mount bolts are the same spacing apart and you need to fab up new front mount
achris
More fish than mountain goat
Need to know the years of each item. 3 items per package (Engine, transom assembly, drive)....
