I found a popped out freeze plug on my exhaust manifold. I fixed that. I still have water leaking in the back of the motor only when its running. If I put a hose on my flush port I get no water leaks. 3 questions
1 Is the freeze plug/crack the only thing that could be leaking?
2 Do I pull the motor or can I pull the outdrive to fix it?
3 How do I stop this from happing again. I did drain the water out of the head and block. I left the drains open as well.
