3.0L idle way too low
matt167
I was running my '86 donor boat on muffs today and it runs great except it idles at about 200 rpm out of gear. If I advance the throttle just a little it clears up at about 750 rpm. How is the idle screw supposed to be sitting on the idle cam for initial adjustment? because I'm pretty sure someone was playing mechanic.. This is an '86 Alpha Gen 1 140hp 3.0L. I was running it on a 12 gallon external tank with fresh gas
Ayuh,.... Snuggly enough to idle at 600/ 700 rpms,......
Scott06
Yeah I know it needs a good tune up. But the engine runs quite and nice. Everything works too
The screw that holds the cam in that the idle speed screw seats against can back out, had it come off on the water on me one time.
matt167
Interesting. The cam itself looks right. Nothings loose
Scott06
If the cam isn’t flopping around you r good
The screw is a flat head with about a 1/4” dia head not sure how mine loosened up by basically wouldn’t idle until it was tightened back up
